[mapserver-dev] Layer opacity is not being saved with mapserver-7-0
thomas bonfort
thomas.bonfort at gmail.com
Wed May 18 11:36:25 PDT 2016
Tamas,
Can you open an issue for this and include a complete mapfile + request
to reproduce please. I'll have a look but am afk for another week and a
half.
Regards,
Thomas
On May 18, 2016 17:59, "Tamas Szekeres" <szekerest at gmail.com> wrote:
> Hi All,
> As far as I see the layer opacity setting is not saved by mapserver to the
> map file in the 7-0 branch, though it is saved in the master branch.
> In the 7-0 branch , when I set the opacity in the map file manually as
> follows:
> LAYER
> COMPOSITE
> OPACITY 70
> END
> END
> the application is crashing when loading that map file. This is because
> the temp image created has null map reference and the truetype font
> (hashtable) lookup causes the crash.
> Any ideas to fix this?
> Thanks,
> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160518/b8041acc/attachment.html>
