[mapserver-dev] Layer opacity is not being saved with mapserver-7-0
Tamas Szekeres
szekerest at gmail.com
Wed May 18 12:05:30 PDT 2016
Hi Thomas,
Thank you will do so.
I'll also review the code tomorrow to see if this is something trivial to
fix.
Best regards,
Tamas
2016-05-18 20:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> Tamas,
> Can you open an issue for this and include a complete mapfile + request
> to reproduce please. I'll have a look but am afk for another week and a
> half.
> Regards,
> Thomas
> On May 18, 2016 17:59, "Tamas Szekeres" <szekerest at gmail.com> wrote:
>> Hi All,
>> As far as I see the layer opacity setting is not saved by mapserver to
>> the map file in the 7-0 branch, though it is saved in the master branch.
>> In the 7-0 branch , when I set the opacity in the map file manually as
>> follows:
>> LAYER
>> COMPOSITE
>> OPACITY 70
>> END
>> END
>> the application is crashing when loading that map file. This is because
>> the temp image created has null map reference and the truetype font
>> (hashtable) lookup causes the crash.
>> Any ideas to fix this?
>> Thanks,
>> Tamas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160518/61495bfd/attachment.html>
