[mapserver-dev] Layer opacity is not being saved with mapserver-7-0
lars.schylberg at blixtmail.se
Thu May 19 01:17:19 PDT 2016
That sounds good! I have also had inconsistent behavior with transparency in MS7.0. I showed it to Tomas B at the code sprint in Paris, but I haven't managed to produce a good example when it happens.
/Lars S.
-----Ursprungsligt meddelande-----
Från: "Tamas Szekeres" <szekerest at gmail.com>
Till: "thomas bonfort" <thomas.bonfort at gmail.com>
Kopia: "MapServer Dev Mailing List" <mapserver-dev at lists.osgeo.org>
Datum: 2016-05-18 21:05
Ämne: Re: [mapserver-dev] Layer opacity is not being saved with mapserver-7-0
Hi Thomas,
Thank you will do so.
I'll also review the code tomorrow to see if this is something trivial to fix.
Best regards,
Tamas
2016-05-18 20:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
Tamas,
Can you open an issue for this and include a complete mapfile + request to reproduce please. I'll have a look but am afk for another week and a half.
Regards,
Thomas
On May 18, 2016 17:59, "Tamas Szekeres" <szekerest at gmail.com> wrote:
Hi All,
As far as I see the layer opacity setting is not saved by mapserver to the map file in the 7-0 branch, though it is saved in the master branch.
In the 7-0 branch , when I set the opacity in the map file manually as follows:
LAYER
COMPOSITE
OPACITY 70
END
END
the application is crashing when loading that map file. This is because the temp image created has null map reference and the truetype font (hashtable) lookup causes the crash.
Any ideas to fix this?
Thanks,
Tamas
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20160519/b15fa1e8/attachment.html>
