[mapserver-dev] Fwd: Re: [OSGeo-Standards] Web Feature Service (WFS) and Axis Order
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Oct 19 09:30:28 PDT 2016
Forwarding to the MapServer-dev list, as it is an interesting discussion...
-------- Forwarded Message --------
Subject: Re: [OSGeo-Standards] Web Feature Service (WFS) and Axis Order
Date: Wed, 19 Oct 2016 10:21:38 -0600
To: standards at lists.osgeo.org
Dear OSGeo community -
I have subscribed to the GeoServer list but have not yet been approved
so I am posting to this list.
As you may know years ago I facilitates a lengthy and at time lively OGC
discussion on Axis Order and CRS. The result of these discussions was
OGC member approval of the OGC Axis Order policy and guidance
(http://www.ogcnetwork.net/axisorder).
Given this background, Esri recently approached me about some
ambiguities and confusions regarding the history and evolution of how
axis order was expressed in a Web Feature Service implementation
instance. After review of various OGC WFS documents and discussions with
the Editor (Peter Vretanos) I compiled the following information. I will
be sharing the same information with the OGC Architecture Board and
staff. Apparently, the CRS axis order issue never really "dies"!!
I bring this information to your attention so that perhaps the GeoServer
community can update their WFS Axis Order web page content to be
consistent with the following. Any questions in that regard, please let
me know. Onto the discussion.
Part of the confusion is probably due to changing OGC policies over the
last 15 years. Examples are the 2008 Axis Order Guidance policy
(08-138r5) and later the http uri policy (in TC Policy Directives).
Anyway, in 2013 the WFS 1.1.1 corrigendum corrected the axis order issue
to be consistent with the Axis Order policy as well as other OGC standards.
Short synopsis: Before WFS 1.1.1 the only sure thing was that the axis
order was LON/LAT when the notation "EPSG:4326" was used to define the
CRS and otherwise was undefined. For WFS 1.1.1 and later, the OGC Axis
Order policy was in force which meant and still means that the axis
order is defined by the CRS being referenced, such as lat/lon for EPSG 4326.
The longer answers is:
How any WFS instance interprets axis order depends on the version of the
WFS standard implemented and the notation being used to specify the CRS.
Based on the WMS 1.0 model, WFS 1.0.0 used the notation EPSG:XXXX for
specifying CRSs. The implication was (although it was never explicitly
stated) that the WFS would do what WMS did and what the WMS did was to
say that for EPSG:4326 the axis order was LON/LAT. This was actually
also consistent with GML 2.1.1. For example:
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326
<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opengis.net_gml_srs_epsg.xml-234326&d=DQMFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=LCXhcrMdvdcRNz8NUgOEV1cYOakNFpC9sSTsSszC0Kc&m=HY5mDJJy4-L8dvfBgWuyrG9fxDiNEyFRZNZCetAE2kY&s=cz2ENba-ejcGrGosCxt7VCq5sYUHu7GlMCLq3G1jO2M&e=>">
<gml:coordinates>-180.0,-90.0 180.0,90.0</gml:coordinates>
</gml:Box>
The WMS 1.0 standard did not say anything about any other EPSG code and
so other CRS behavior was undefined. As a result, most WFS 1.0.0
implementations stuck with LON/LAT regardless of the EPSG code being used.
WFS 1.1.0 specified several notations for defining the CRS: EPSG:XXXX,
http://www.opengis.net/gml/src/epsg.xml#XXXX
<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opengis.net_gml_src_epsg.xml-23XXXX&d=DQMFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=LCXhcrMdvdcRNz8NUgOEV1cYOakNFpC9sSTsSszC0Kc&m=HY5mDJJy4-L8dvfBgWuyrG9fxDiNEyFRZNZCetAE2kY&s=vcSZ-tEvudUXHYfE6HX2WUCkg5qjM9X5ULCLBSADUkw&e=>,
urn:EPSG:geographicCRS:XXXX. The EPSG:XXXX notation was maintained for
backward compatibility with WFS 1.1. As such, a WFS implementation
instance would behave as it did in WFS 1.0.0 (i.e. LON/LAT for
EPSG:4326, undefined otherwise). The other two notations were meant to
follow the then being developed OGC Axis Order policy which eventually
provided clear policy guidance on how to express and document axis
order. The recommended option is to use the axis order as defined in the
EPSG CRS definition. However, at the time WFS 1.1 was being processed
the Axis Order policy and notation were still in flux. Ultimately the
URL and URN notations specified in the WFS 1.1 standard were invalid.
This problem was, however, addressed in the WFS 1.1.1 corrigendum.
Unfortunately, for some reason that corrigendum was never published
thereby increasing the WFS axis order confusion. This oversight is being
addressed by OGC staff.
Which brings us to WFS 1.1.1 and 2.0.X. In these versions, the same
Axis Order policy is specified: Do what the EPSG CRS definition says.
Also, at the same time the srsName expression changed to the http uri
notation (i.e. http://www.opengis.net/dev/crs/epsg/0/xxxx
<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.opengis.net_dev_crs_epsg_0_xxxx&d=DQMFaQ&c=n6-cguzQvX_tUIrZOS_4Og&r=LCXhcrMdvdcRNz8NUgOEV1cYOakNFpC9sSTsSszC0Kc&m=HY5mDJJy4-L8dvfBgWuyrG9fxDiNEyFRZNZCetAE2kY&s=otM5bDnCQOb9DY-U_pSooY0tHUmXzTpcwfIOXZvwxyk&e=>).
This is because in 2010 the OGC policy changed regarding how to identify
resources. The OGC moved from urn's to using URLs as identifiers. Even
so, the initial version of WFS 2.0 used the URN notation
(urn:ogc:def:crs:EPSG:<ver>:XXXX). This changed in WFS 2.0.2
(corrigendum). All of the urn references were changed to URLs with notes
on what the older "urn" strings were.
Which brings us to the GeoServer documentation. That documentation is
not quite right and should be corrected to reflect reality and what is
actually in the various versions of the WFS standards. Further, the
GeoServer documentation mentions the use of "urn:x-". I am not sure
where that is coming from as none of the WFS standards from WFS 1.0 and
later use that notation.
Regards
Carl
Carl Reed, PhD
Carl Reed and Associates
Mobile: 970-402-0284
"When the power of love overcomes the love of power the world will know
peace." Jimi Hendrix
