[mapserver-dev] PHP 7 MapScript SWIG Support / Discussion
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Feb 2 06:45:43 PST 2017
Thanks for taking the time to review the RFC Thomas.  I agree with both
of your ideas, and have updated the RFC document.  I think over time
full compatibility will be reached, but it is best to keep both
available in the short term (in their separate directories, generating
separate module names).  I'll update my test environment with those changes.
-jeff
On 2017-01-24 2:38 AM, thomas bonfort wrote:
> Jeff,
> Given that the proposal does not address the issue of backwards
> compatibility with the current php mapscript, I suggest that (1) the
> whole php+swig code reside in its own mapscript/(phpng|php7) directory
> instead of having #ifdefs in the current php mapscript code, and that
> (2) the module be renamed differently than the current one. When/if a
> backwards compatibility layer is worked on, that compatibility layer
> could take on the current name.
> regards,
> thomas
> On Tue, Jan 3, 2017 at 4:53 PM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     Update: SWIG-3.0.11 was released recently on 29 December containing the
>     full PHP 7 support.
>     -jeff
>     On 2016-12-20 5:58 PM, Jeff McKenna wrote:
>     > Regarding the clone() keyword, I looked closer at the MapServer
>     source,
>     > and in fact Java MapScript faced the same issue apparently, and
>     handled
>     > that by defining a new function name for those use cases (cloning map,
>     > layer, class, style, shape instances) such as:
>     > #ifdef SWIGJAVA
>     >   %newobject cloneMap;
>     >   mapObj *cloneMap()
>     > #else
>     >   %newobject clone;
>     >   mapObj *clone()
>     > #endif
>     > So we would do the same for SWIGPHP (reference them in the /swiginc/
>     > files and define those functions in /mapscript/php/phpextend.i
>     > (I've updated the RFC with those notes)
>     > Thanks for the feedback Ducky!
>     > -jeff
>     > On 2016-12-19 10:49 AM, Dan Little wrote:
>     >> I'm generally positive about this in the hopes that it means the
>     >> PHP/MapScript+SWIG will ensure PHP gets feature parity with the other
>     >> versions of MapScript.  I also am a fan of what looks to be a more
>     >> consistent syntax to modern PHP.
>     >> I'll venture an opinion/suggestions on the reserved word cases
>     >> (specifically clone and close):   Is there a way to alias those
>     >> function names to something other than "c_..." ?  If so, I've seen
>     >> some convention such as "clone_" or "close_", and more PHP-y might be
>     >> something to the tune of "cloneInstance()" or "closeXYZ" where XYZ is
>     >> actual context appropriate (closeStream, closeConnection, etc.).
>     >> Cheers.
>     >> On Mon, Dec 19, 2016 at 9:47 AM, Dan Little
>     <theduckylittle at gmail.com <mailto:theduckylittle at gmail.com>>
>     other
>     might be
>     XYZ is
>     >>> Cheers.
>     >>> On Fri, Dec 16, 2016 at 4:32 PM, Jeff McKenna
>     <mailto:jmckenna at gatewaygeomatics.com>> wrote:
>     >>>> Hi all,
>     >>>> I've created an RFC draft for the PHP 7 SWIG potential changes:
>     >>>> http://mapserver.org/development/rfc/ms-rfc-117.html
>     >>>> Please pay attention to the "Limitations" section, as there are
>     some
>     >>>> items
>     >>>> that need discussion.  I will plan to discuss this for sure at the
>     >>>> next PSC
>     >>>> meeting on 19 January, so we have lots of time to discuss,
>     >>>> especially as we
>     >>>> are entering the holidays.
>     >>>> Wishing the whole MapServer community a truly happy and merry
>     >>>> Christmas!  :)
>     >>>> -jeff
>     _______________________________________________
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
