[mapserver-dev] Skip failures when drawing a map
Tamas Szekeres szekerest at gmail.com
Tue Feb 21 12:26:29 PST 2017
Hi Devs,
Would that be a reasonable option to skip layers which are failing to draw
and don't abort the entire drawing session?
If yes, should that be a per-layer or per-map setting?
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170221/cbbc4bea/attachment.html>
