[mapserver-dev] Skip failures when drawing a map
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Tue Feb 21 12:40:26 PST 2017
We used to have a compile time option (oddly enough) to skip missing data errors and keep processing. So yes, I think it’s reasonable.
I assume failing is generally an issue with msLayerOpen() although other errors (e.g. missing columns, etc…) can happen too. At first glance I’d think this would be a layer level configuration (perhaps a processing directive) since you’d likely be tolerant of stuff breaking in some cases but not others.
Steve
From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Tuesday, February 21, 2017 2:26 PM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Skip failures when drawing a map
Hi Devs,
Would that be a reasonable option to skip layers which are failing to draw and don't abort the entire drawing session?
If yes, should that be a per-layer or per-map setting?
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170221/07c749aa/attachment.html>
