[mapserver-dev] Skip failures when drawing a map
Tamas Szekeres szekerest at gmail.com
Tue Feb 21 13:33:19 PST 2017
Steve,
I'm not sure about a specific failure, this is upon user request.
Probably they would just ignore everything that cause failures for that
layer.
Tamas
2017-02-21 21:40 GMT+01:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> On 2/21/2017 3:26 PM, Tamas Szekeres wrote:
>> Hi Devs,
>> Would that be a reasonable option to skip layers which are failing to
>> draw and don't abort the entire drawing session?
>> If yes, should that be a per-layer or per-map setting?
> Tamas,
> How is the layer failing? this is probably key to the problem.
> For example we already have CONFIG ON_MISSING_DATA "IGNORE", what other
> failures should we ignore?
> Maybe:
> CONFIG ON_CONNECTION_FAILURE "IGNORE"
> CONFIG ON_BAD_DATA_FILE "IGNORE"
> others?
> Some of these may or may not be easy to recover from.
> -Steve W
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170221/efadc6c0/attachment-0001.html>
