[mapserver-dev] [mapserver-users] Label position not as expected version 7.0.x
thomas bonfort thomas.bonfort at gmail.com
Tue Jan 3 04:22:25 PST 2017
correct. the position of "center of the text" varies depending on whether
your glyphs have ascenders and/or descenders, and thus produces
inconsistent centering between "aaa", "ppp" or "bbbb".
This can be easily reverted by commenting out the two special cases for CR
and CL at
https://github.com/mapserver/mapserver/blob/rel-7-0-3/maplabel.c#L989 .
replace with
y1 = (h/2.0) + oy;
thomas
On Mon, Jan 2, 2017 at 6:58 PM Ian Walberg <ian.walberg at airborne.aero>
wrote:
> Thomas.
> Hmm, I do not understand why the change was made from the older versions.
> So the vertical ‘center’ position is actually align the text baseline with
> the point position and not the ‘center’ of the text as previously?
> Regards
> Ian
> *From:* thomas bonfort [mailto:thomas.bonfort at gmail.com]
> *Sent:* Monday, January 2, 2017 9:41 AM
> *To:* Ian Walberg <ian.walberg at airborne.aero>;
> mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Label position not as expected version
> 7.0.x
> Ian,
> It's the intented effect, with the label baseline aligned with the symbol
> baseline. You can probably nudge it manually with an offset if you need to.
> thomas
> On Mon, Jan 2, 2017 at 6:30 PM Ian Walberg <ian.walberg at airborne.aero>
> wrote:
> Folks,
> Happy New Year to everyone.
> Using version 7.0.x we are not seeing the label positon as we had for
> previous versions for mapserver.
> The vertical label position now appears to not center naturally on the
> text but is towards the bottom of the center line.
> Are we missing something?
> Thanks
> Ian
> MAP
>   EXTENT 0.0 0.0 10.0 10.0
>   SIZE 1024 720
>   IMAGECOLOR 140 140 140
>   SYMBOL
>     NAME 'City'
>     TYPE ELLIPSE
>     POINTS 1 1 END
>     FILLED true
>   END
>   LAYER
>     NAME "Label position"
>     TYPE POINT
>     STATUS DEFAULT
>     FEATURE
>         POINTS
>           1.00 5.00
>           1.00 8.00
>         END # POINTS
>     END # FEATURE
>     CLASS
>       TEXT 'Label text'
>       STYLE
>         SYMBOL 'City'
>         SIZE 12
>         COLOR 255 255 255
>       END # STYLE
>       LABEL
>         TYPE BITMAP
>         SIZE 30
>         COLOR 255 255 255
>         POSITION CR
>       END # LABEL
>     END # CLASS
>   END # LAYER
> END # MAP
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170103/10e0857e/attachment-0001.html>
