[mapserver-dev] [mapserver-users] Label position not as expected version 7.0.x
Ian Walberg ian.walberg at airborne.aero
Tue Jan 3 07:47:53 PST 2017
Thomas,
Understood that the historic vertical alignment is not perfect.
I would like to propose that an additional vertical positon mode is added to allow the previous behavior to be retained.
Regards
Ian
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Tuesday, January 3, 2017 4:22 AM
To: Ian Walberg <ian.walberg at airborne.aero>; mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-users] Label position not as expected version 7.0.x
correct. the position of "center of the text" varies depending on whether your glyphs have ascenders and/or descenders, and thus produces inconsistent centering between "aaa", "ppp" or "bbbb".
This can be easily reverted by commenting out the two special cases for CR and CL at https://github.com/mapserver/mapserver/blob/rel-7-0-3/maplabel.c#L989 . replace with
y1 = (h/2.0) + oy;
thomas
On Mon, Jan 2, 2017 at 6:58 PM Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>> wrote:
Thomas.
Hmm, I do not understand why the change was made from the older versions.
So the vertical ‘center’ position is actually align the text baseline with the point position and not the ‘center’ of the text as previously?
Regards
Ian
From: thomas bonfort [mailto:thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>]
Sent: Monday, January 2, 2017 9:41 AM
To: Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>; mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Ian,
It's the intented effect, with the label baseline aligned with the symbol baseline. You can probably nudge it manually with an offset if you need to.
thomas
On Mon, Jan 2, 2017 at 6:30 PM Ian Walberg <ian.walberg at airborne.aero<mailto:ian.walberg at airborne.aero>> wrote:
Folks,
Happy New Year to everyone.
Using version 7.0.x we are not seeing the label positon as we had for previous versions for mapserver.
The vertical label position now appears to not center naturally on the text but is towards the bottom of the center line.
Are we missing something?
Thanks
Ian
MAP
  EXTENT 0.0 0.0 10.0 10.0
  SIZE 1024 720
  IMAGECOLOR 140 140 140
  SYMBOL
    NAME 'City'
    TYPE ELLIPSE
    POINTS 1 1 END
    FILLED true
  END
  LAYER
    NAME "Label position"
    TYPE POINT
    STATUS DEFAULT
    FEATURE
        POINTS
          1.00 5.00
          1.00 8.00
        END # POINTS
    END # FEATURE
    CLASS
      TEXT 'Label text'
      STYLE
        SYMBOL 'City'
        SIZE 12
        COLOR 255 255 255
      END # STYLE
      LABEL
        TYPE BITMAP
        SIZE 30
        COLOR 255 255 255
        POSITION CR
      END # LABEL
    END # CLASS
  END # LAYER
END # MAP
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170103/c9d64ea5/attachment-0001.html>
