[mapserver-dev] Force GeoTools SLDTransformer to write out defaults (or force MapServer to recognise a default value when it doesn't see it)
Andrea Aime andrea.aime at geo-solutions.it
Mon Jan 9 09:47:22 PST 2017
Hi Ian,
I don't think SLDTransformer has any way to control that, but adding a
property so that
boolean isDefault(Expression expr, Object defaultValue) returns false
always should not be hard
Cheers
Andrea
On Mon, Jan 9, 2017 at 6:45 PM, Ian Turton <ijturton at gmail.com> wrote:
> I've run into an issue with MapServer not recognising <Stroke/> as a 1px
> black line (it draws nothing :-) ) - eventually I'll try to get a fix into
> their code base but as a short term fix is there someway to force GeoTools'
> SLDTransformer to output the default values. I can only find references to
> the GeoServer raw parameter (which would be great if I was uploading with
> REST) on the web.
> Ian
> Ian Turton
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170109/9d0afb32/attachment.html>
