[mapserver-dev] wms_layer_group and GROUP parameter
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Jan 12 03:00:03 PST 2017
Hello,
Currently the MS source code doesn't allow to setup a wms_layer_group for a
layer in the same time that a GROUP parameter in the same layer. This lead to
an error message [1].
In a similar way, if we use wms_layer_group (with a/b/c as a value) in a layer
who referenced another layer (let's says b) with a GROUP parameter, the
wms_layer_group feature doesn't work as expected (there is a missing b node in
the tree).
I see that the source code for [1] have been changed by tbonfort and Schpidi.
Do you think that the problem above can't be corrected?
Thanks for your feedback,
Y.
[1] https://github.com/mapserver/mapserver/blob/branch-7-0/mapwms.c#L347-L352
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 58 48 20 43 (new !)
Tel (Suisse) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
