[mapserver-dev] Mapfile keywords questions
Seth G
sethg at geographika.co.uk
Thu Jun 29 05:28:53 PDT 2017
Thanks Steve for all the details.
I'm not sure why I had SCALETOKEN in the list. Maybe however this block
deserves its own page in the docs?
SCALE is referred to on the http://mapserver.org/mapfile/map.html page,
but only as part of the newer SCALEDENOM keyword. Should it be added as
its own keyword, with a deprecated tag? Also are all the keywords listed
at http://mapserver.org/cgi/controls.html Mapfile keywords, or are they
a separate but similar set?
I'm happy to take care of creating a ticket for updating the docs, and
fix these where appropriate.
Regards,
Seth
On 29/06/2017 13:53, Lime, Steve D (MNIT) wrote:
> Agreed. I guess I can do it... there are a couple of instance where
> doc updates probably aren't warranted IMHO (simple, compfilter).
> That's up for debate...
> Re:LATLON... More info, that parameter takes a projection string. It
> allows you to override the default geographic projection used by
> MapServer.
> --Steve
> *From:* mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on
> behalf of Stephen Woodbridge <woodbri at swoodbridge.com>
> *Sent:* Wednesday, June 28, 2017 1:02:16 PM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* Re: [mapserver-dev] Mapfile keywords questions
> Hmmm, sounds like there should be two tickets opened:
> 1. one for code changes at
> https://github.com/mapserver/mapserver/issues
> <https://github.com/mapserver/mapserver/issues>
> 2. one for doc changes at https://github.com/mapserver/docs/issues
> -Steve W
> On 6/28/2017 1:21 PM, Lime, Steve D (MNIT) wrote:
> > Hi Seth: Results of my research... Thanks for sharing yours. I think
> you've identified a few places where some cleanup is warranted. --Steve
> > *RELATIVETO - I don't believe this is in use. Should be removed.
> > *COMPFILTER - My take is that COMPFILTER, while part of the
> enhancement, is not actually functional in any meaningful way so it's
> not worth documenting beyond RFC 113 at this point.
> > *GRATICULE - more research needed here. I'm not regular user of
> graticule/grid functionality, but it has not been formally deprecated.
> > *SCALETOKEN - is documented in detail here:
> http://mapserver.org/mapfile/layer.html
> <http://mapserver.org/mapfile/layer.html>.
> > *LATLON - this is processed at the map level as a shortcut to define
> a second geographic projection independent of the map->projection.
> Presumably something like "LATLON TRUE". It is used in some places in
> the CGI and template handling for projection to geographic
> coordinates. Probably should examine the need for it as it is not
> documented anywhere...
> > *JAVASCRIPT - I don't believe the token is needed. I imagine it was
> a holdover when the thought was that block of javascript could defined
> within a mapfile. Instead referencing an external file was pursued.
> > *SCALE - This is valid within the map object and is a parameter for
> CGI/FCGI and documented here: http://mapserver.org/mapfile/map.html.
> The idea is/was to set an explicit scale, center point and size and
> then let MapServer compute a matching extent rather than the other way
> around.
> > *INDEX - I don't believe this is in use. Should be removed.
> > *SIMPLE - This is a valid TYPE value within a SYMBOL object. It's
> actually the default value (e.g. a pixel) and is never set explicitly
> - hence the lack of documentation.
> > *TITLE - still a valid property for a class but deprecated. Should
> be considered for removal.
> > *VALUES - Part of the SCALETOKEN implementation and is covered there.
> > *COLORRANGE and DATARANGE - We've always considered that
> functionality experimental and ripe for refactoring and haven’t wanted
> to encourage their use. Lame, but that's my story... ;-)
> > *BANDSITEM - I don't believe this is in use. Should be removed. The
> bandsitem and bandsitemindex still exist as part of the layer object
> but are unused...
> > *OVERLAYSYMBOL - It's a deprecated CLASS-level keyword from the
> pre-STYLE days. It sets the SYMBOL property of the second style. It's
> there for backwards compatibility only.
> > *EQUALS - token is valid within the context of MapServer expression
> parsing. Represents geometry (GEOS) equality...
> > *MULTIPLE, SINGLE - I don't see why we need these keywords when we
> have ONE-TO-ONE and ONE-TO-MANY. We're lucky MS_ONE_TO_ONE =
> MS_SINGLE, etc... and that should be fixed in loadJoin()...
> > *LINECAP - I concur with the missing triangle option.
> > -----Original Message-----
> > From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org]
> On Behalf Of Seth G
> > Sent: Friday, June 23, 2017 6:33 PM
> > To: mapserver-dev at lists.osgeo.org
> > Subject: [mapserver-dev] Mapfile keywords questions
> > Hi list,
> > I'm trying to get the definitive list of current Mapfile keywords and
> > syntax for a Mapfile parser I'm working on
> > (https://github.com/geographika/mappyfile).
> > I've gone through the MapServer docs, and also the sourcecode and have a
> > few keywords that aren't documented and I'm not sure are still used. If
> > anyone has any details on the list below it would be very useful. I can
> > open issues if necessary and update docs.
> > RELATIVETO - mentioned in
> > https://github.com/mapserver/mapserver/issues/1547 (from 2006) and is in
> > the maplexer.l file. It is not in the test mapfile created when the
> > issue was resolved
> (https://trac.osgeo.org/mapserver/attachment/ticket/1547/test_points.map).
> > So it may never have been used?
> > COMPFILTER -
> http://www.mapserver.org/development/rfc/ms-rfc-113.html
> <http://www.mapserver.org/development/rfc/ms-rfc-113.html> -
> > not used? Looks interesting! Should be added to
> > http://www.mapserver.org/mapfile/composite.html ?
> > GRATICULE - used to be a LAYER CONNECTION type, but now deprecated?
> > SCALETOKEN - should be in
> http://www.mapserver.org/mapfile/layer.html
> <http://www.mapserver.org/mapfile/layer.html>
> > Documented in http://www.mapserver.org/output/kerneldensity.html
> > LATLON - in maplexer.l but not sure where this would be used in a
> Mapfile.
> > JAVASCRIPT - it is a token in maplexer.l, but not sure where this would
> > be needed (javascript is in quotes as part of the GEOTRANSFORM options)
> > SCALE - again a token, but I can only find it as a LAYER processing
> > option - PROCESSING "SCALE=AUTO"
> > INDEX - not sure what this keyword is for (and hard to search for..)
> > SIMPLE, TITLE, VALUES - all in maplexer.l but not in docs.
> > COLORRANGE and DATARANGE - should be added to the STYLE doc page -
> > currently only documented at
> http://mapserver.org/output/kerneldensity.html
> <http://mapserver.org/output/kerneldensity.html>
> > Some keywords only seem valid as part of Mapscript rather than a
> > Mapfile: BANDSITEM, OVERLAYSYMBOL, EQUALS, MULTIPLE, SINGLE (I think the
> > last 2 are PHP join types only?)
> > Also some non-quoted values also seem to be missing from the docs:
> > LINECAP - http://www.mapserver.org/mapfile/style.html?highlight=linecap
> > - should TRIANGLE be a documented option? It is in maplexer.l and also
> > mentioned at
> http://www.mapserver.org/mapfile/symbology/construction.html#sym-construction
> > Regards,
> > Seth
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> mapserver-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
web: http://geographika.co.uk
twitter: @geographika
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20170629/dfb95adf/attachment-0001.html>
