[mapserver-dev] FIX: default values for variable substitution in WEB section
Martin Icking
martin.icking at bentley.com
Fri Nov 10 06:26:53 PST 2017
Currently a default value for substitution variables in the map's WEB section
is ignored. I've created a fix to this, pls see this pull request:
https://github.com/mapserver/mapserver/pull/5516
This enables you now to set a default value for e.g. the ows_onlineresource
setting as illustrated below.
Use case: have a correct capabilities reply behind a proxy software (with
dynamic URI's)
WEB
VALIDATION
'default_ows_onlineresource' 'https://defaultserver/defaultpath'
'ows_onlineresource' '^https://[a-z0-9/:.?&=]+$'
END
METADATA
'ows_onlineresource' '%ows_onlineresource%'
END # METADATA
END # WEB
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html
