[mapserver-dev] FIX: default values for variable substitution in WEB section
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Nov 13 13:08:16 PST 2017
Thanks for this Martin. I have merged this, and asked if you can
contribute a note about this for the docs. -jeff
On 2017-11-10 10:26 AM, Martin Icking wrote:
> Currently a default value for substitution variables in the map's WEB section
> is ignored. I've created a fix to this, pls see this pull request:
> https://github.com/mapserver/mapserver/pull/5516
> This enables you now to set a default value for e.g. the ows_onlineresource
> setting as illustrated below.
> Use case: have a correct capabilities reply behind a proxy software (with
> dynamic URI's)
> WEB
> VALIDATION
> 'default_ows_onlineresource' 'https://defaultserver/defaultpath'
> 'ows_onlineresource' '^https://[a-z0-9/:.?&=]+$'
> END
> METADATA
> 'ows_onlineresource' '%ows_onlineresource%'
> END # METADATA
> END # WEB
