[mapserver-dev] MOTION to adopt RFC 118 - Vendor-specific WMS FILTER param
Daniel Morissette
dmorissette at mapgears.com
Wed Sep 20 15:03:42 PDT 2017
For the record, after Even fixed the Travis config, the updated RFC 118
pull request passed all tests and has been merged into master.
Daniel
On 2017-09-20 4:17 PM, Daniel Morissette wrote:
> Hi everyone,
> I declare this motion passed with +1 from TomK, SteveL, JukkaR, SteveW,
> MichaelS, StephanM, JeffM and DanielM.
> I updated the RFC to reflect the vote results and also indicate a
> limitation that was found in testing: since this uses the QUERYMAP
> mechanism for rendering, the OPACITY, COMPOSITE and MASK layer options
> are not supported in filtered layers because msDrawQueryMap() doesn't
> implement them. (Fixing this QueryMap limitation is out of scope for
> this RFC)
> The code has been tested for a little while in a few apps and is ready
> to merge into master for 7.2 in the following pull request:
> https://github.com/mapserver/mapserver/pull/5480
> Unfortunately the Travis builds are broken at the moment, so I wonder if
> I should merge into master anyway, or wait for Travis to be fixed. Any
> opinions on this?
> Daniel
> On 2017-08-15 5:41 PM, Daniel Morissette wrote:
>> We had the discussion on RFC 118 back in February and the code in my
>> fork (https://github.com/dmorissette/mapserver/tree/rfc118-filter) has
>> been in use in a few apps since, but we haven't voted to include it
>> officially in 7.2 yet.
>> So unless there is more feedback, I'll move to adopt MS RFC 118 -
>> Support Vendor-Specific OGC FILTER parameter in WMS requests:
>> http://mapserver.org/development/rfc/ms-rfc-118.html
>> And I start with my +1
>> Daniel
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
