[mapserver-dev] Pull requests to master or branch-7-2?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Aug 17 15:49:39 PDT 2018
On 2018-08-17 6:38 PM, Even Rouault wrote:
> On vendredi 17 août 2018 23:08:05 CEST Seth G wrote:
>> Hi devs,
>> Should new pull requests be made to master or the 7-2 branch?
> But fixes that apply to 7-2 should go against to 7-2
>> I believe it should be on the 7-2 branch according to
>> https://github.com/mapserver/mapserver/wiki/WorkingWithGit and then there
>> is a script that applies these to master? There are a few changes in the
>> 7-2 branch that aren't in master, so I'm not sure how/when this process
>> takes place.
> Wasn't aware of that script, and it appears to be outdated referencing old
> branches.
> Just manually resynced master with 7.2 with:
> git checkout branch-7-2
> git pull origin
> git checkout master
> git pull origin
> git merge branch-7-2
> git push origin master
It's also a manual sync for the docs, there might be a script but lately
it's been manual. -jeff
