[mapserver-dev] Pull requests to master or branch-7-2?
Seth G
sethg at geographika.co.uk
Sat Aug 18 11:40:12 PDT 2018
Thanks Even.
I made the Python build pull request (https://github.com/mapserver/mapserver/pull/5645) against master as I guess this is a new development rather than a fix.
If new wheels need to be built I guess they will be for a future 7.4 release.
Please advise otherwise if I'm incorrect.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Aug 17, 2018, at 11:38 PM, Even Rouault wrote:
> On vendredi 17 août 2018 23:08:05 CEST Seth G wrote:
> > Hi devs,
> > Should new pull requests be made to master or the 7-2 branch?
> But fixes that apply to 7-2 should go against to 7-2
> > I believe it should be on the 7-2 branch according to
> > https://github.com/mapserver/mapserver/wiki/WorkingWithGit and then there
> > is a script that applies these to master? There are a few changes in the
> > 7-2 branch that aren't in master, so I'm not sure how/when this process
> > takes place.
> Wasn't aware of that script, and it appears to be outdated referencing old
> branches.
> Just manually resynced master with 7.2 with:
> git checkout branch-7-2
> git pull origin
> git checkout master
> git pull origin
> git merge branch-7-2
> git push origin master
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
