[mapserver-dev] testing needed of OSGeoLive package running MapServer 7.2
Seth G
sethg at geographika.co.uk
Thu Aug 23 22:47:01 PDT 2018
Hi Angelos/Jeff,
I setup a VM with latest ISO. The Quickstart works perfectly with the
new 7.2 version.I also ran the Python test suite against the build and everything is
passing. I also setup msautotest and ran those - as expected there are
several failures likely due to different OSs being used to generate
the images.Summary - looks good to me.
I have documented the OSGeoLive/MapServer test script at:
https://github.com/mapserver/mapserver/wiki/OSGeoLive-MapServer-Testing
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Aug 24, 2018, at 12:23 AM, Angelos Tzotsos wrote:
> Hi all,
> This is a last-minute call for testing since MapServer 7.0.3 was to be
> included in OSGeoLive 12.0.> I made a build with 7.2.0 for testing with the hope everything
> works fine...>
> Cheers,
> Angelos
> On Fri, Aug 24, 2018 at 1:22 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:>> about the build:
>> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+sourcepub/9355111/+listing-archive-extra>>
>> iso:
>> http://aiolos.survey.ntua.gr/gisvm/dev/osgeolive-nightly-build287-amd64-cc5da74-staging.iso>>
>> main site (quickstart steps for setting virtual machine with that):>> https://live.osgeo.org/en/index.html
>> providing feedback: #osgeolive channel on IRC
>> -from Angelos and OSGeoLive team
>> -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
> _________________________________________________
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20180824/ee61f7c7/attachment.html>
