[mapserver-dev] testing needed of OSGeoLive package running MapServer 7.2
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Aug 24 01:26:37 PDT 2018
Thank you Seth,
MapServer 7.2.0 it is then :)
Best,
Angelos
On Fri, Aug 24, 2018 at 8:47 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi Angelos/Jeff,
> I setup a VM with latest ISO. The Quickstart works perfectly with the new
> 7.2 version.
> I also ran the Python test suite against the build and everything is
> passing. I also setup msautotest and ran those - as expected there are
> several failures likely due to different OSs being used to generate the
> images.
> Summary - looks good to me.
> I have documented the OSGeoLive/MapServer test script at:
> https://github.com/mapserver/mapserver/wiki/OSGeoLive-MapServer-Testing
> Regards,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Fri, Aug 24, 2018, at 12:23 AM, Angelos Tzotsos wrote:
> Hi all,
> This is a last-minute call for testing since MapServer 7.0.3 was to be
> included in OSGeoLive 12.0.
> I made a build with 7.2.0 for testing with the hope everything works
> fine...
> Cheers,
> Angelos
> On Fri, Aug 24, 2018 at 1:22 AM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
> about the build:
> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+sourcepub/9355111/+listing-archive-extra
> iso:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeolive-nightly-build287-amd64-cc5da74-staging.iso
> main site (quickstart steps for setting virtual machine with that):
> https://live.osgeo.org/en/index.html
> providing feedback: #osgeolive channel on IRC
> -from Angelos and OSGeoLive team
> -jeff
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Angelos Tzotsos, PhD
> OSGeo Charter Member
> http://users.ntua.gr/tzotsos
> *_______________________________________________*
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20180824/f5a010fe/attachment-0001.html>
