[mapserver-dev] problems compiling mapserver 7.2.1 with php7 and harfbuzz on debian9
Linsenmaier Dierk Dierk.Linsenmaier at regiodata-gmbh.de
Wed Dec 5 04:15:52 PST 2018
Hello Devs,
I have problems compiling mapserver 7.2.1 with php7 and harfbuzz on Debian 9.
Compilation fails with error:
//usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to `hb_buffer_set_cluster_level'
Last lines oft he whole output:
8<
cd /usr/local/src/mapserver/mapserver-7.2.1/build && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /usr/local/src/mapserver/mapserver-7.2.1 /usr/local/src/mapserver/mapserver-7.2.1 /usr/local/src/mapserver/mapserver-7.2.1/build /usr/local/src/mapserver/mapserver-7.2.1/build /usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/DependInfo.cmake --color=
Dependee "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/DependInfo.cmake" is newer than depender "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/depend.internal".
Dependee "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/CMakeDirectoryInformation.cmake" is newer than depender "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/depend.internal".
Scanning dependencies of target shptreetst
make[2]: Leaving directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
make -f CMakeFiles/shptreetst.dir/build.make CMakeFiles/shptreetst.dir/build
make[2]: Entering directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
[ 69%] Building C object CMakeFiles/shptreetst.dir/shptreetst.c.o
/usr/bin/cc   -I/usr/local/src/mapserver/mapserver-7.2.1/build -I/usr/local/src/mapserver/mapserver-7.2.1/renderers/agg/include -I/usr/local/src/mapserver/mapserver-7.2.1/mapscript/v8 -I/usr/include/freetype2 -I/usr/local/src/mapserver/mapserver-7.2.1/build/renderers/mvt -I/usr/include/cairo -I/usr/include/oracle/18.3/client64 -I/usr/include/postgresql -I/usr/include/gdal -I/usr/include/librsvg-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/x86_64-linux-gnu -I/usr/include/libxml2  -Wall -Werror=format-security -Wdeclaration-after-statement -O3 -DNDEBUG   -o CMakeFiles/shptreetst.dir/shptreetst.c.o   -c /usr/local/src/mapserver/mapserver-7.2.1/shptreetst.c
[ 70%] Linking CXX executable shptreetst
/usr/bin/cmake -E cmake_link_script CMakeFiles/shptreetst.dir/link.txt --verbose=1
/usr/bin/c++    -Wall -Werror=format-security -O3 -DNDEBUG   CMakeFiles/shptreetst.dir/shptreetst.c.o  -o shptreetst  -L/usr/lib/oracle/18.3/client64/lib -Wl,-rpath,/usr/lib/oracle/18.3/client64/lib::::::::::::::: -rdynamic libmapserver_static.a -lpng -lz -ljpeg -lfreetype -lproj -lprotobuf-c -lcairo /usr/lib/oracle/18.3/client64/lib/libclntsh.so /usr/lib/oracle/18.3/client64/lib/libocci.so -lnnz18 -lgeos_c -lpq -lgdal -lrsvg-2 -lgobject-2.0 -lcurl -lxml2 -lpthread -lgif -ldl -lm
collect2: error: ld returned 1 exit status
CMakeFiles/shptreetst.dir/build.make:113: recipe for target 'shptreetst' failed
make[2]: *** [shptreetst] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/shptreetst.dir/all' failed
make[1]: *** [CMakeFiles/shptreetst.dir/all] Error 2
make[1]: Leaving directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
>8
I start compilation with these options:
/usr/local/src/mapserver/mapserver-7.2.1/build# cmake -DWITH_PROJ=1 -DWITH_KML=0 -DWITH_SOS=0 -DWITH_WMS=1 -DWITH_FRIBIDI=0 -DWITH_HARFBUZZ=0       -DWITH_ICONV=1 -DWITH_CAIRO=1 -DWITH_SVGCAIRO=0 -DWITH_RSVG=1 -DWITH_MYSQL=0 -DWITH_FCGI=0 -DWITH_GEOS=1       -DWITH_POSTGIS=1 -DWITH_GDAL=1 -DWITH_OGR=1 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_CURL=1       -DWITH_WFS=0 -DWITH_WCS=0 -DWITH_LIBXML2=1 -DWITH_THREAD_SAFETY=1 -DWITH_GIF=1 -DWITH_PHP=1       -DWITH_POINT_Z_M=0 -DWITH_ORACLESPATIAL=1 -DLINK_STATIC_LIBMAPSERVER=1 -DCMAKE_PREFIX_PATH="/usr/local"       -DGOBJECT_INCLUDE_DIRS="/usr/include/glib-2.0" -DCMAKE_BUILD_TYPE=Release   ../
I compiled harfbuzz on the same server libraries are in /usr/local/lib.
Do you have any hint how to solve this problem?
Thanks in advance
Dierk
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20181205/7d0beb2b/attachment.html>
