[mapserver-dev] problems compiling mapserver 7.2.1 with php7 and harfbuzz on debian9
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Dec 5 04:52:44 PST 2018
Hi Dierk,
For MS4W on Windows I have the same configuration (MapServer 7.2.1,
PHP7, Harfbuzz 1.9.0) successfully. From your logs it looks like you
have not enabled Harfbuzz in your make/cmake command. -jeff
PS. feel lucky that you're not trying that on Windows ;)
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2018-12-05 8:15 AM, Linsenmaier Dierk wrote:
> Hello Devs,
> I have problems compiling mapserver 7.2.1 with php7 and harfbuzz on
> Debian 9.
> Compilation fails with error:
> //usr/lib/x86_64-linux-gnu/libpangoft2-1.0.so.0: undefined reference to
> `hb_buffer_set_cluster_level'
> Last lines oft he whole output:
> 8<
> cd /usr/local/src/mapserver/mapserver-7.2.1/build && /usr/bin/cmake -E
> cmake_depends "Unix Makefiles" /usr/local/src/mapserver/mapserver-7.2.1
> /usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/DependInfo.cmake
> --color=
> Dependee
> "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/DependInfo.cmake"
> is newer than depender
> "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/shptreetst.dir/depend.internal".
> Dependee
> "/usr/local/src/mapserver/mapserver-7.2.1/build/CMakeFiles/CMakeDirectoryInformation.cmake"
> Scanning dependencies of target shptreetst
> make[2]: Leaving directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
> make -f CMakeFiles/shptreetst.dir/build.make CMakeFiles/shptreetst.dir/build
> make[2]: Entering directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
> [ 69%] Building C object CMakeFiles/shptreetst.dir/shptreetst.c.o
> /usr/bin/cc -I/usr/local/src/mapserver/mapserver-7.2.1/build
> -I/usr/local/src/mapserver/mapserver-7.2.1/renderers/agg/include
> -I/usr/local/src/mapserver/mapserver-7.2.1/mapscript/v8
> -I/usr/include/freetype2
> -I/usr/local/src/mapserver/mapserver-7.2.1/build/renderers/mvt
> -I/usr/include/cairo -I/usr/include/oracle/18.3/client64
> -I/usr/include/postgresql -I/usr/include/gdal -I/usr/include/librsvg-2.0
> -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng16
> -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include
> -I/usr/include/pixman-1 -I/usr/include/x86_64-linux-gnu
> -I/usr/include/libxml2 -Wall -Werror=format-security
> -Wdeclaration-after-statement -O3 -DNDEBUG -o
> CMakeFiles/shptreetst.dir/shptreetst.c.o -c
> /usr/local/src/mapserver/mapserver-7.2.1/shptreetst.c
> [ 70%] Linking CXX executable shptreetst
> /usr/bin/cmake -E cmake_link_script CMakeFiles/shptreetst.dir/link.txt
> --verbose=1
> /usr/bin/c++ -Wall -Werror=format-security -O3 -DNDEBUG
> CMakeFiles/shptreetst.dir/shptreetst.c.o -o shptreetst
> -L/usr/lib/oracle/18.3/client64/lib
> -Wl,-rpath,/usr/lib/oracle/18.3/client64/lib::::::::::::::: -rdynamic
> libmapserver_static.a -lpng -lz -ljpeg -lfreetype -lproj -lprotobuf-c
> -lcairo /usr/lib/oracle/18.3/client64/lib/libclntsh.so
> /usr/lib/oracle/18.3/client64/lib/libocci.so -lnnz18 -lgeos_c -lpq
> -lgdal -lrsvg-2 -lgobject-2.0 -lcurl -lxml2 -lpthread -lgif -ldl -lm
> collect2: error: ld returned 1 exit status
> CMakeFiles/shptreetst.dir/build.make:113: recipe for target 'shptreetst'
> failed
> make[2]: *** [shptreetst] Error 1
> CMakeFiles/Makefile2:67: recipe for target
> 'CMakeFiles/shptreetst.dir/all' failed
> make[1]: *** [CMakeFiles/shptreetst.dir/all] Error 2
> make[1]: Leaving directory '/usr/local/src/mapserver/mapserver-7.2.1/build'
> Makefile:127: recipe for target 'all' failed
> make: *** [all] Error 2
> >8
> I start compilation with these options:
> /usr/local/src/mapserver/mapserver-7.2.1/build# cmake -DWITH_PROJ=1
> -DWITH_KML=0 -DWITH_SOS=0 -DWITH_WMS=1 -DWITH_FRIBIDI=0
> -DWITH_HARFBUZZ=0 -DWITH_ICONV=1 -DWITH_CAIRO=1 -DWITH_SVGCAIRO=0
> -DWITH_RSVG=1 -DWITH_MYSQL=0 -DWITH_FCGI=0 -DWITH_GEOS=1
> -DWITH_POSTGIS=1 -DWITH_GDAL=1 -DWITH_OGR=1 -DWITH_CLIENT_WMS=1
> -DWITH_CLIENT_WFS=1 -DWITH_CURL=1 -DWITH_WFS=0 -DWITH_WCS=0
> -DWITH_LIBXML2=1 -DWITH_THREAD_SAFETY=1 -DWITH_GIF=1 -DWITH_PHP=1
> -DWITH_POINT_Z_M=0 -DWITH_ORACLESPATIAL=1 -DLINK_STATIC_LIBMAPSERVER=1
> -DCMAKE_PREFIX_PATH="/usr/local"
> -DGOBJECT_INCLUDE_DIRS="/usr/include/glib-2.0"
> -DCMAKE_BUILD_TYPE=Release ../
> I compiled harfbuzz on the same server libraries are in /usr/local/lib.
> Do you have any hint how to solve this problem?
> Thanks in advance
> Dierk
