[mapserver-dev] setPattern in symbolObj in PHP MapScript
Nicol Hermann mapserver at geoworld.de
Fri Dec 14 06:51:31 PST 2018
Hello Developers,
I am unclear about the pattern support in the symbolObj of PHP
MapScript.
Its documented to be supported at:
https://mapserver.org/mapscript/php/phpmapscript.html#symbolobj
but essentially it fails with a segmentation fault when I am using the
7.3dev git master branch (PHP 7.1).
This happens regardless if the symbol is constructed as documented
above or as part of a symbol file.
I wonder if it has moved to the stypeObject where also a pattern
property exist.
Can somebody please clarify this?
Thanks
Nicol
