[mapserver-dev] Issue with WFS requests to SQL server with datetime columns
Martin Icking
martin.icking at bentley.com
Mon Jan 22 08:27:37 PST 2018
Let's say I have data stored in MS SQL Server, and there are DataTime columns
in the table. When the client tries to make a GetFeature request on the
server, I got this error on MapServer:
msParseTime(): Regular expression error. Unrecognized date or time format
(Apr 25 2018 12:00AM).
I look at the code in mapmssql2008.c, in function prepare_database(), there
is such a piece of code:
#ifdef USE_ICONV
snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer),
"convert(nvarchar(max), [%s]),", layer->items[t]);
#else
"convert(varchar(max), [%s]),", layer->items[t]);
#endif
It uses CONVERT() function to convert the column value to strings. When it
handles datetime, the default format for MS SQL Server is:
mon dd yyyy hh:miAM/PM (e.g. Apr 25 2018 12:00AM)
However, according to this following link:
http://mapserver.org/ogc/wms_time.html
MapServer only supports these datatime formats:
Time Patterns Examples
YYYYMMDD 20041012
YYYY-MM-DDTHH:MM:SSZ 2004-10-12T13:55:20Z
YYYY-MM-DDTHH:MM:SS 2004-10-12T13:55:20
YYYY-MM-DD HH:MM:SS 2004-10-12 13:55:20
YYYY-MM-DDTHH:MM 2004-10-12T13:55
YYYY-MM-DD HH:MM 2004-10-12 13:55
YYYY-MM-DDTHH 2004-10-12T13
YYYY-MM-DD HH 2004-10-12 13
YYYY-MM-DD 2004-10-12
YYYY-MM 2004-10
YYYY 2004
THH:MM:SSZ T13:55:20Z
THH:MM:SS T13:55:20
That's why it causes the problem. I would suggest adding a format parameter
when calling CONVERT() for DateTime data. For example, we can use 120 format
(yyyy-mm-dd hh:mi:ss). In function prepare_database(), we can probably add
this following code piece:
if (layerinfo->itemtypes && (layerinfo->itemtypes[t] == SQL_TYPE_DATE ||
layerinfo->itemtypes[t] == SQL_TYPE_TIME || layerinfo->itemtypes[t] ==
SQL_TYPE_TIMESTAMP)) {
#ifdef USE_ICONV
snprintf(buffer + strlen(buffer), bufLen - strlen(buffer),
"convert(nvarchar(max), [%s], 120),", layer->items[t]);
#else
"convert(varchar(max), [%s], 120),", layer->items[t]);
#endif
Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html
