[mapserver-dev] Issue with WFS requests to SQL server with datetime columns
Seth G
sethg at geographika.co.uk
Mon Jan 22 12:00:43 PST 2018
Are you thinking of a new processing parameter for the layer?
E.g.
PROCESSING 'DATE_FORMAT=YYYY-MM-DD hh:mm:ss'
Seth
web:http://geographika.co.uk
twitter: @geographika
On Mon, Jan 22, 2018, at 5:27 PM, Martin Icking wrote:
> Let's say I have data stored in MS SQL Server, and there are DataTime columns
> in the table. When the client tries to make a GetFeature request on the
> server, I got this error on MapServer:
> msParseTime(): Regular expression error. Unrecognized date or time format
> (Apr 25 2018 12:00AM).
> I look at the code in mapmssql2008.c, in function prepare_database(), there
> is such a piece of code:
> #ifdef USE_ICONV
> snprintf(buffer + strlen(buffer), sizeof(buffer) - strlen(buffer),
> "convert(nvarchar(max), [%s]),", layer->items[t]);
> #else
> "convert(varchar(max), [%s]),", layer->items[t]);
> #endif
> It uses CONVERT() function to convert the column value to strings. When it
> handles datetime, the default format for MS SQL Server is:
> mon dd yyyy hh:miAM/PM (e.g. Apr 25 2018 12:00AM)
> However, according to this following link:
> http://mapserver.org/ogc/wms_time.html
> MapServer only supports these datatime formats:
> Time Patterns Examples
> YYYYMMDD 20041012
> YYYY-MM-DDTHH:MM:SSZ 2004-10-12T13:55:20Z
> YYYY-MM-DDTHH:MM:SS 2004-10-12T13:55:20
> YYYY-MM-DD HH:MM:SS 2004-10-12 13:55:20
> YYYY-MM-DDTHH:MM 2004-10-12T13:55
> YYYY-MM-DD HH:MM 2004-10-12 13:55
> YYYY-MM-DDTHH 2004-10-12T13
> YYYY-MM-DD HH 2004-10-12 13
> YYYY-MM-DD 2004-10-12
> YYYY-MM 2004-10
> YYYY 2004
> THH:MM:SSZ T13:55:20Z
> THH:MM:SS T13:55:20
> That's why it causes the problem. I would suggest adding a format parameter
> when calling CONVERT() for DateTime data. For example, we can use 120 format
> (yyyy-mm-dd hh:mi:ss). In function prepare_database(), we can probably add
> this following code piece:
> if (layerinfo->itemtypes && (layerinfo->itemtypes[t] == SQL_TYPE_DATE ||
> layerinfo->itemtypes[t] == SQL_TYPE_TIME || layerinfo->itemtypes[t] ==
> SQL_TYPE_TIMESTAMP)) {
> #ifdef USE_ICONV
> snprintf(buffer + strlen(buffer), bufLen - strlen(buffer),
> "convert(nvarchar(max), [%s], 120),", layer->items[t]);
> #else
> "convert(varchar(max), [%s], 120),", layer->items[t]);
> #endif
> Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
