[mapserver-dev] Scale computations for non-square pixels...
Daniel Morissette
dmorissette at mapgears.com
Tue Jul 24 14:22:19 PDT 2018
Since you asked for feedback...
I had a look at the WMS 1.3 spec looking for guidance on this question
and don't see a clear mention of whether the scaledenom should be based
on the x, y or diagonal pixel size. The spec seems to assume square
pixels for scaledenom witout being explicit about it (section
7.2.4.6.9). All we find in the spec is a mention (in 7.3.3.8) that if
WIDTH and HEIGHT don't match that will result in non-square pixels, but
the spec does not address the impact on the scaledenom.
Personally I'd be tempted to go with scale based on the diagonal cell
size just because that would be more or less an average of the x and y
scales, so one would think it should work fine in more cases. However I
could be mistaken since I don't know the reasons why the current
approach was selected originally.
Daniel
On 2018-07-24 11:22 AM, Lime, Steve D (MNIT) wrote:
> Hi all: We have a ticket out there regarding scale computation with
> non-square pixels (see
> https://github.com/mapserver/mapserver/issues/5625). It should be easy
> to implement a fix, to the extent it’s possible to come up with a single
> scale value when that’s
> really not the case. Any opinions on what a “best” approach would be?
> --Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
