[mapserver-dev] Time for a 7.2.1 release?
Seth G
sethg at geographika.co.uk
Fri Sep 28 10:53:37 PDT 2018
In this case I'm referring to the Python test suite (that has been
recently updated for Python3) at
https://github.com/mapserver/mapserver/tree/master/mapscript/python/tests
- there are also Python tests in msautotests that should maybe be moved
here also.The Python wheel now generated by CMake includes the test suite and
accompanying test data from
https://github.com/mapserver/mapserver/tree/master/testsThis makes it easier to check a Python MapScript deployment is fully
functioning.The examples are in
https://github.com/mapserver/mapserver/tree/master/mapscript/python/examples
- these refer to dbf libraries that may no longer exist, and could do
with some cleanup - I'm looking at these at the moment, but new examples
won't be ready for the 7.2.1 release.Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Sep 28, 2018, at 2:24 PM, Lime, Steve D (MNIT) wrote:
> We’ve tried to definitely include examples with MapScript over the
> years. Depends what you mean by tests. Seems like all the regression
> tests should be in msautotest or are you thinking something different?> *From:* mapserver-dev <mapserver-dev-bounces at lists.osgeo.org> on
> behalf of Seth G <sethg at geographika.co.uk> *Sent:* Thursday, September
> 27, 2018 5:10:16 PM *To:* mapserver-dev at lists.osgeo.org *Subject:* Re:
> [mapserver-dev] Time for a 7.2.1 release?>
> Hi Steve / list,
> A more frequent release cycle (at least for patch releases) sounds
> good to me. I'll aim to release a new Python MapScript wheel on PyPI
> (for Windows) on each new release which will allow incremental
> improvements (flake8 has just been added and the test suite updated
> to have a consistent code standard -
> https://github.com/mapserver/mapserver/pull/5670).
> There are some useful notes on Python MapScript and Ubuntu builds
> (from Sebastiaan Couwenberg) are in this thread -
> https://lists.osgeo.org/pipermail/ubuntu/2018-September/thread.html#1752
> Does anyone have any opinions on whether MapScript should be deployed
> with tests and examples? I'm currently updating both and will be
> trying to get these added to patch releases.
> Regards,
> Seth
> web:http://geographika.co.uk twitter: @geographika
> On Thu, Sep 27, 2018, at 7:02 AM, Sebastiaan Couwenberg wrote:
> > On 9/26/18 9:02 PM, Lime, Steve D (MNIT) wrote:
> > > Seems to me that more frequent releases would be a good thing...
> > Yes. Release early, release often.
> > Kind Regards,
> > Bas
> > mapserver-dev mailing list mapserver-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20180928/585c5f3a/attachment.html>
