[mapserver-dev] Memory leak in mapcache
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Fri Apr 12 00:41:52 PDT 2019
I'm using mapcache v1.6.1 (tested as well with a master build) in docker
and I can see huge memory increases in the apache process memory usage when
mapcache is used (it's the only thing this apache instance is serving). The
thing is configured like that:
<mapcache>
<cache name="default" type="memcache">
<server>
<host>prod-2-4-c2cgeoportal-memcached</host>
<port>11211</port>
</server>
</cache>
<tileset name="map">
<source>map</source>
<cache>default</cache>
<grid>swissgrid_005</grid>
<metatile>5 5</metatile>
<metabuffer>128</metabuffer>
<format>image/png</format>
<expires>3600</expires> <!-- 1 hour -->
<auto_expire>13800</auto_expire> <!-- 4 hours -->
</tileset>
I can see that memcached is used in it's stats and only mapcache uses it.
But the the memory usage of the whole mapcache container looks like that:
[image: image.png]
Each dip in usage is when the OOM kills one of the apache workers (out of a
maximum of 3 workers). I have configured a memory limit in docker at 512MB.
Nothing shows up in the apache logs.
Are there any known memory leaks? Do I have a bad configuration? I could
have the apache workers restarted every 10 queries, but that would be
utterly ugly and inefficient...
Thanks for your help.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190412/1942ff0a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190412/1942ff0a/attachment-0001.png>
