[mapserver-dev] Memory leak in mapcache
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 12 10:12:26 PDT 2019
Hi Patrick,
What kind of requests is mapcache responding to, and at what concurrency?
Serving multiple large wms requests is typically an example where large
chunks of memory will be allocated.
thomas
On Fri, Apr 12, 2019 at 12:42 AM Patrick Valsecchi <
patrick.valsecchi at camptocamp.com> wrote:
> Hi,
> I'm using mapcache v1.6.1 (tested as well with a master build) in docker
> and I can see huge memory increases in the apache process memory usage when
> mapcache is used (it's the only thing this apache instance is serving). The
> thing is configured like that:
> <mapcache>
> <cache name="default" type="memcache">
> <server>
> <host>prod-2-4-c2cgeoportal-memcached</host>
> <port>11211</port>
> </server>
> </cache>
> <tileset name="map">
> <source>map</source>
> <cache>default</cache>
> <grid>swissgrid_005</grid>
> <metatile>5 5</metatile>
> <metabuffer>128</metabuffer>
> <format>image/png</format>
> <expires>3600</expires> <!-- 1 hour -->
> <auto_expire>13800</auto_expire> <!-- 4 hours -->
> </tileset>
> I can see that memcached is used in it's stats and only mapcache uses it.
> But the the memory usage of the whole mapcache container looks like that:
> [image: image.png]
> Each dip in usage is when the OOM kills one of the apache workers (out of
> a maximum of 3 workers). I have configured a memory limit in docker at
> 512MB.
> Nothing shows up in the apache logs.
> Are there any known memory leaks? Do I have a bad configuration? I could
> have the apache workers restarted every 10 queries, but that would be
> utterly ugly and inefficient...
> Thanks for your help.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190412/df9f9c92/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190412/df9f9c92/attachment-0001.png>
