[mapserver-dev] Dropping support for GDAL < 2 ?
Tamas Szekeres
szekerest at gmail.com
Thu Aug 22 06:29:29 PDT 2019
Even,
I agree with dropping the support if needed.
The open option seems to be a driver specific attribute, wouldn't it be
sufficient to use a processing directive for that?
Best regards,
Tamas
Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2019. aug.
22., Cs, 12:44):
> Hi,
> I'd like to propose to drop support for GDAL < 2 in master.
> I'm currently adding a new mapfile keyword LAYER.OPENOPTION to be able to
> specify open options to GDAL and OGR drivers, which is a new feature of
> GDAL
> 2. While I can conditionnalize that by testing the GDAL version, I see
> this
> more as cluttering of the codebase than something really needed.
> GDAL 2.0 was released in June 2015 and is available in the latest stable
> versions of Debian, Ubuntu, Fedora, etc.
> Travis-CI uses GDAL 2.2 (from UbuntuGIS)
> gisinternals builds used by AppVeyor even ship with GDAL 3.1dev
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190822/6e7c83e4/attachment.html>
