[mapserver-dev] OPENOPTION (was Re: Dropping support for GDAL < 2 ?)
Even Rouault
even.rouault at spatialys.com
Fri Aug 23 05:01:02 PDT 2019
> A new Mapfile keyword will require changes for SWIG support I believe?
In my initial implementation, this adds a new member (a hashTableObj) in the
struct layerObj. I don't think this would require specific SWIG changes.
> My preference from a syntax point of view (although blissfully unaware of
> the implementation issues it will raise!) would be to turn PROCESSING into
> a block with the same syntax as METADATA e.g.
> PROCESSING
> "CONTOUR_INTERVAL" "5"
> "CLUSTER_GET_ALL_SHAPES" ON"
> "OPENOPTION_KEY1" "VALUE1"
> "OPENOPTION_KEY2" "VALUE2"
> END
On the parser side there would be some complication to distinguish the old
PROCESSING "key=value" syntax with the new block approach. I'm not sure we
have a precedent of that.
And the processing member of layerObj is not exposed to SWIG currently. It
uses a char** processing + int numprocessing that are inconvenient to bind to
SWIG. They should likely be converted to a hashTableObj to be exposed to SWIG.
> SWIG could then use a dict type approach in the same way as METADATA to
> update and add, modify keys and values in the PROCESSING block.
If OPENOPTION uses a hashTableObj as METADATA does, then this would be similar
to interacting with metadata.
I'm also open to a block based approach for OPENOPTION if that seems better
OPENOPTION
"key1" "value1"
"key2" "value2
END
Even
http://www.spatialys.com
