[mapserver-dev] OPENOPTION (was Re: Dropping support for GDAL < 2 ?)
Even Rouault even.rouault at spatialys.com
Fri Aug 23 06:55:08 PDT 2019
On vendredi 23 août 2019 13:30:56 CEST Lime, Steve D (MNIT) wrote:
> Would CONNECTIONOPTIONS be more generic? I could see that being useful for
> other drivers where key:value pairs are used as part of the configuration.
Yes, I agree that the mechanism could potentially be used for other connection
types.
For completness, you'd probably also want a DATAOPTIONS to pass options
specific to the DATA keyword. I've always found the syntax for PostGIS data to
be a bit awkward.
So instead of
DATA "the_geom from (select * from polygon3d order by id) as foo using
srid=27700 using unique id"
you could have
DATA "select * from polygon3d order by id"
DATAOPTIONS
	"geometry_column"	"the_geom"
	"srid"					"27700"
	"unique_column"		"id"
END
But this is just food for thought, and we probably don't want to break
existing PostGIS DATA syntax.
My scope for now would be just CONNECTIONOPTIONS and implementation for GDAL
and OGR connections.
> For 8.0 a broader conversion of the syntax for layer->processing and
> outputformat->formatoptions could be implemented. For the latter you'd get:
> OUTPUTFORMAT
>   NAME "kayml"
>   DRIVER "TEMPLATE"
>   MIMETYPE "application/vnd.google-earth.kml+xml"
>   OPTIONS
>     "FILE" "myTemplate.kml"
>     "ATTACHMENT" "queryResults.kml"
>   END
> END
> In this case you could ensure backwards compatibility by adding recognizing
> FORMATOPTION as a shortcut.
> Perhaps a new PROCESSINGOPTIONS block should be added and PROCESSING is
> handled as a shortcut for backwards compatability.
Makes sense
Even
http://www.spatialys.com
