[mapserver-dev] mapscript csharp and dotnet core on Linux
Seth G
sethg at geographika.co.uk
Sun Jan 13 15:36:34 PST 2019
Hi Rui,
Having the C# bindings work on DotNet core/Linux would be a very useful feature in my view - congratulations on getting this far. I'm not not a huge user of the C# bindings (more Python), but worked with the code briefly as part of https://github.com/mapserver/mapserver/pull/5583 to get them working on the newer versions of SWIG. There were ~1,500 errors due to missing namespaces (basically putting System. in front of lots of type declarations) - I see there are a few more in the pull request so no harm adding these. Several of the issues you address look like they can be fixed with checking the compiler/OS in CMake and adding IF statements.
If you have the time/inclination to try and tidy these changes up in to a pull request (or a few separate ones), I can try to review/test. To merge these we should probably try and build the C# bindings as part of the Travis CI (they are already built on Windows with Appveyor). For info there is a planned 7.4 release in late March or early April which has several MapScript updates (Python3, PHP7), so it may be possible to add this as a 7.4 feature.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Sun, Jan 13, 2019, at 9:59 PM, ruigis wrote:
> Hi guys, another "sunny" day in Ireland so I decided to make mapserv run
> on
> dotnet core.
> Could you guys take a look at
> http://osgeo-org.1560.x6.nabble.com/csharp-mapscript-dotnet-core-on-Linux-td5391329.html
> <http://osgeo-org.1560.x6.nabble.com/csharp-mapscript-dotnet-core-on-Linux-td5391329.html
> there is a commit mentioned in there with a few changes I did on my fork,
> probably most were not needed, but I would like to know what of it could
> actually be useful and what is not useful why not so I could probably add it
> to the documentation.
> dotnet core is cross platform is I think it would be very useful to have
> mapscript_csharp cross platform as well. Probably there are guys out there
> already using mapscript on Linux, at first soght what we have seems not to
> be compatible to be compilable on Linux.
> Sent from: http://osgeo-org.1560.x6.nabble.com/Mapserver-Dev-f4252683.html
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
