[mapserver-dev] Expire tiles and update new after Postgres DB update using mapcache
Seth G
sethg at geographika.co.uk
Sat Jul 27 12:28:24 PDT 2019
If you know the list of tiles that have expired, can't you script deleting these, and then regenerate the cache?
mapcache_seed should skip generating any existing tiles. I'm unaware of any inbuilt way of doing this.
There is a RFC at https://mapserver.org/development/rfc/ms-rfc-122.html that may be of interest/relevance to you in the future.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Sat, Jul 27, 2019, at 6:52 AM, parsis presswala wrote:
> I have developed the map using MapServer and pre-generated tile using mapcache. Now I have an idea to update the database every day. As changes apply in the database only those parts should be re-render and new tile should be generated. As changes are very small and rendering all ties from start is difficult to process.
> I got expiry list of tiles by following osm2pgsql:
> osm2pgsql --append --slim --cache 1000 --multi-geometry /home/parsis/diff_file_minute.xml --number-processes 2 --hstore -d testdemo -r xml -e6-11 -o /home/parsis/expire.list
> Got list something like this:
> ` - 11/329/713
- 8/40/91
- 10/164/357
- 7/29/47`
> I find another approach using render_expired <https://ircama.github.io/osm-carto-tutorials/manpage.html?url=https://rawgit.com/openstreetmap/mod_tile/master/docs/render_expired.1>, but don't know how to use it with mapcache.
> How is it possible using mapcache_seed?
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190727/db9ea3cf/attachment.html>
