[mapserver-dev] Expire tiles and update new after Postgres DB update using mapcache
parsis presswala
parsispresswala at gmail.com
Fri Jul 26 21:52:30 PDT 2019
I have developed the map using MapServer and pre-generated tile using
mapcache. Now I have an idea to update the database every day. As changes
apply in the database only those parts should be re-render and new tile
should be generated. As changes are very small and rendering all ties from
start is difficult to process.
I got expiry list of tiles by following osm2pgsql:
osm2pgsql --append --slim --cache 1000 --multi-geometry
/home/parsis/diff_file_minute.xml --number-processes 2 --hstore -d testdemo
-r xml -e6-11 -o /home/parsis/expire.list
Got list something like this:
- 11/329/713
- 8/40/91
- 10/164/357
- 7/29/47
I find another approach using render_expired
<https://ircama.github.io/osm-carto-tutorials/manpage.html?url=https://rawgit.com/openstreetmap/mod_tile/master/docs/render_expired.1>,
but don't know how to use it with mapcache.
How is it possible using mapcache_seed?
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20190727/0c195d60/attachment.html>
