[mapserver-dev] 7.4 Release...
michael.smith.erdc at gmail.com michael.smith.erdc at gmail.com
Sat Mar 16 05:11:18 PDT 2019
I think we go ahead with a 7.4 release now and we plan for an 8.0 release with proj 6. I version upgrade seems to tie in well with a significant change like this. We can plan and start work on this at the code sprint and perhaps release near FOSS4G?
MapServer <8 will be max PROJ 5.x and MapServer >=8 will be PROJ 6+?
Mike
> On Mar 16, 2019, at 7:11 AM, Lime, Steve D (MNIT) <steve.lime at state.mn.us> wrote:
> Hi all: We’re due to start the 7.4 release process now. I have one question for folks regarding Proj 7 support. As it sits now MapServer cannot use the newest version of Proj. It can use Proj 6 by means of a compile-time flag.
> Even didn’t think Proj 7 support would be a trivial change and we might not be able to support both older and newer versions of the lib. Ideally we’d abandon versions older than 6 - there are likely several reasons to do that.
> Question is when. Could wait on 7.4 or we could release 7.4 (PHP folks have been more than patient) and work in earnest on Proj 7 support in the next 7.6 or 8.0 release. I’m in favor of the latter but could be convinced otherwise...
> —Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
