[mapserver-dev] using master as default branch again
Tom Kralidis
tomkralidis at gmail.com
Fri May 17 11:27:34 PDT 2019
Thanks Jeff.
On Fri, May 17, 2019 at 1:46 PM Jeff McKenna
<jmckenna at gatewaygeomatics.com> wrote:
> Tom, all, the default branch has been changed to master on github.
> -jeff
> On 2019-05-16 5:38 PM, Tom Kralidis wrote:
> > Hi all: as discussed at today's meeting, I tabled the idea of
> > making MapServer's default branch as master (instead of
> > the stable branch). The value proposition here would be
> > to potentially lessen the burden of bug fixes across branches
> > as well as a more familiar workflow especially for new
> > developers to contribute.
> > I know we used to have this setup in the past, and then moved
> > to the stable branch as the default branch, however it's a good
> > time to revisit and change given the above.
> > Thoughts/comments?
> > Thanks
> > ..Tom
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
