[mapserver-dev] Dropping support for non-GDAL and non-PROJ builds
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Nov 29 08:02:12 PST 2019
Regarding users compiling this, how would they know that GDAL+PROJ are
required, if we remove WITH-GDAL and WITH-PROJ from the cmake syntax?
(those cmake hints are a lifeline for compiling software I find).
-jeff
On 2019-11-29 11:21 AM, Even Rouault wrote:
> Just at the distance of pressing the "Merge" button:
> https://github.com/mapserver/mapserver/pull/5935
> The diff stat is pretty eloquent about the benefits:
>   54 files changed, 118 insertions(+), 1298 deletions(-)
> Said otherwise, 0.7% of the total number of lines of .c/.cpp code gone.
> I didn't even realize there were so many #ifdef before removing them :-) !
> Even
