[mapserver-dev] Dropping support for non-GDAL and non-PROJ builds
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Nov 29 08:29:57 PST 2019
On 2019-11-29 12:13 PM, Even Rouault wrote:
> On vendredi 29 novembre 2019 12:02:12 CET Jeff McKenna wrote:
>> Regarding users compiling this, how would they know that GDAL+PROJ are
>> required, if we remove WITH-GDAL and WITH-PROJ from the cmake syntax?
>> (those cmake hints are a lifeline for compiling software I find).
> Exactly as they would figure out for other required dependencies we have
> already (libpng, libjpeg, libfreetype). cmake will loudly and clearly complain
> about what's wrong:
> -- Could NOT find PROJ (missing: PROJ_LIBRARY)
> CMake Error at CMakeLists.txt:79 (message):
> PROJ library/component could not be found and is a mandatory dependency
> HINT:
> - add the PROJ install directory to the CMAKE_PREFIX_PATH variable (-
> DCMAKE_PREFIX_PATH="/path/to/PROJ-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
> CMakeLists.txt:390 (report_mandatory_not_found)
I meant besides battling through cmake errors. cmake command has a
switch "-LA" that lists all available options (WITH_PHP, WITH_PIXMAN,
etc) that is very useful when compiling a new software, and learning of
all its dependencies. But it sounds like there is no way to tell users
of these hidden requirements (at least not from my googling).
-jeff
