[mapserver-dev] "ambiguity" of gml_[item name]_type = Date
Even Rouault
even.rouault at spatialys.com
Tue Oct 22 13:48:22 PDT 2019
when serving vector through WFS currently, we can use the gml_[item name]_type
to define the type of a field. Currently we have a value "Date" whose
semantics is rather loose. All input backends (OGR, Oracle, MSSQL, PostGIS)
use it whereas they have distinct types for Date (without time), DateTime, and
Time (without date). MapServer having internally a single type makes that when
using OGR output (for example GeoJSON), we'll have lost some information, and
thus the OGR output currently prefers to use a OGR OFTDateTime to avoid
potentially losses. But "2019-10-22T00:00:00Z" is not semantically equivalent
to "2019-10-22".
So my proposal would be to change (define) Date to be a Date without time
information, and add DateTime and Time types.
Thoughts ?
(note: some backends like Oracle and PostGIS have distinctions between
DateTime with or without timezone, but we probably don't need to go to that
level of subtelty)
Even
http://www.spatialys.com
