[mapserver-dev] "ambiguity" of gml_[item name]_type = Date
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Oct 22 15:09:46 PDT 2019
It seems I spend a lot of effort playing with datetime and PostGIS
MapServer, so I am a strong +1 in adding a "datetime" and "time" as
valid options for gml_[item name]_type
-jeff
On 2019-10-22 5:54 PM, Steve Lime wrote:
> Makes complete sense to me at firstĀ glance.
> On Tue, Oct 22, 2019 at 3:48 PM Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
>     Hi,
>     when serving vector through WFS currently, we can use the gml_[item
>     name]_type
>     to define the type of a field. Currently we have a value "Date" whose
>     semantics is rather loose. All input backends (OGR, Oracle, MSSQL,
>     PostGIS)
>     use it whereas they have distinct types for Date (without time),
>     DateTime, and
>     Time (without date). MapServer having internally a single type makes
>     that when
>     using OGR output (for example GeoJSON), we'll have lost some
>     information, and
>     thus the OGR output currently prefers to use a OGR OFTDateTime to avoid
>     potentially losses. But "2019-10-22T00:00:00Z" is not semantically
>     equivalent
>     to "2019-10-22".
>     So my proposal would be to change (define) Date to be a Date without
>     time
>     information, and add DateTime and Time types.
>     Thoughts ?
>     (note: some backends like Oracle and PostGIS have distinctions between
>     DateTime with or without timezone, but we probably don't need to go
>     to that
>     level of subtelty)
>     Even
>     Spatialys - Geospatial professional services
>     http://www.spatialys.com
>     _______________________________________________
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
