[mapserver-dev] "ambiguity" of gml_[item name]_type = Date
Daniel Morissette dmorissette at mapgears.com
Wed Oct 23 05:27:09 PDT 2019
+1 here too.
Daniel
On 2019-10-22 18:09, Jeff McKenna wrote:
> It seems I spend a lot of effort playing with datetime and PostGIS
> MapServer, so I am a strong +1 in adding a "datetime" and "time" as
> valid options for gml_[item name]_type
> -jeff
> On 2019-10-22 5:54 PM, Steve Lime wrote:
>> Makes complete sense to me at first glance.
>> On Tue, Oct 22, 2019 at 3:48 PM Even Rouault
>> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
>>     Hi,
>>     when serving vector through WFS currently, we can use the gml_[item
>>     name]_type
>>     to define the type of a field. Currently we have a value "Date" whose
>>     semantics is rather loose. All input backends (OGR, Oracle, MSSQL,
>>     PostGIS)
>>     use it whereas they have distinct types for Date (without time),
>>     DateTime, and
>>     Time (without date). MapServer having internally a single type makes
>>     that when
>>     using OGR output (for example GeoJSON), we'll have lost some
>>     information, and
>>     thus the OGR output currently prefers to use a OGR OFTDateTime to
>> avoid
>>     potentially losses. But "2019-10-22T00:00:00Z" is not semantically
>>     equivalent
>>     to "2019-10-22".
>>     So my proposal would be to change (define) Date to be a Date without
>>     time
>>     information, and add DateTime and Time types.
>>     Thoughts ?
>>     (note: some backends like Oracle and PostGIS have distinctions
>> between
>>     DateTime with or without timezone, but we probably don't need to go
>>     to that
>>     level of subtelty)
>>     Even
>>     --     Spatialys - Geospatial professional services
>>     http://www.spatialys.com
>>     _______________________________________________
>>     mapserver-dev mailing list
>>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
