[mapserver-dev] Undocumented Mapfile COLOR options
Lars Schylberg
lars.schylberg at blixtmail.se
Thu Jul 23 08:43:15 PDT 2020
Hello All,
I wrote about this as my Mapserver Easteregg findings two years ago:
https://lists.osgeo.org/pipermail/mapserver-users/2018-March/080547.html
I also made some different examples in my GIST:
https://gist.github.com/LarsSchy/df91553f1fda02196ba7881a129b4c64
I am not really sure how useful this is.
Sometimes when I want to make color tranparent I throw in a -1 in the
red color column, just because I know I can.
Happy summer
Lars Schylberg
Den 2020-07-22 kl. 23:45, skrev Seth G:
> Hi all,
> Whilst validating various Mapfiles to try and find all valid options I've come across a couple of special values used in msautotest Mapfiles for COLOR - the first is -255 -255 -255 used in classtest1.map [1]
> CLASS
> NAME "Text"
> EXPRESSION ([pixel] == 0)
> COLOR -255 -255 -255
> END
> This value is defined in mapserver.h [2] as follows:
> #define MS_TRANSPARENT_COLOR(color) (((color).alpha==0 || (color).red==-255 || (color).green==-255 || (color).blue==-255)?MS_TRUE:MS_FALSE)
> So can this be set to make a color transparent? Is it a valid value and if so should this be added somewhere in the docs? There is currently no reference.
> The second example is:
> BACKGROUNDCOLOR -1 -1 -1
> LABEL BACKGROUNDCOLOR was removed in 6.0 [3] but is still present in mapserver\msautotest\misc\sde_utf2.map
> One of the Python MapScript tests refers to this value as an "invalid color" that should throw an error [4]
> Any details on these 2 COLOR values appreciated,
> Seth
> [1] https://github.com/mapserver/mapserver/blob/85e294e8c8ce3c9c455fea0137d4af1ee2feced0/msautotest/gdal/classtest1.map#L33
> [2] https://github.com/mapserver/mapserver/blob/06a076e9d0992f3ace676933ddcde87985feea31/mapserver.h#L369
> [3] https://mapserver.org/mapfile/label.html#mapfile-label-backgroundcolor
> [4] https://github.com/mapserver/mapserver/blob/85e294e8c8ce3c9c455fea0137d4af1ee2feced0/mapscript/python/tests/cases/color_test.py#L50
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
