[mapserver-dev] Undocumented Mapfile COLOR options
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Jul 23 09:01:46 PDT 2020
Hi Lars,
Please file your (easter) findings in the "docs" repository as a ticket,
and I'll add them to the documentation (and point to your Gist as it
will help me document them). thanks! -jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-07-23 12:43 p.m., Lars Schylberg wrote:
> Hello All,
> I wrote about this as my Mapserver Easteregg findings two years ago:
> https://lists.osgeo.org/pipermail/mapserver-users/2018-March/080547.html
> I also made some different examples in my GIST:
> https://gist.github.com/LarsSchy/df91553f1fda02196ba7881a129b4c64
> I am not really sure how useful this is.
> Sometimes when I want to make color tranparent I throw in a -1 in the
> red color column, just because I know I can.
> Happy summer
> Lars Schylberg
> Den 2020-07-22 kl. 23:45, skrev Seth G:
>> Hi all,
>> Whilst validating various Mapfiles to try and find all valid options
>> I've come across a couple of special values used in msautotest
>> Mapfiles for COLOR - the first is -255 -255 -255 used in
>> classtest1.map [1]
>> CLASS
>> NAME "Text"
>> EXPRESSION ([pixel] == 0)
>> COLOR -255 -255 -255
>> END
>> This value is defined in mapserver.h [2] as follows:
>> #define MS_TRANSPARENT_COLOR(color) (((color).alpha==0 ||
>> (color).red==-255 || (color).green==-255 ||
>> (color).blue==-255)?MS_TRUE:MS_FALSE)
>> So can this be set to make a color transparent? Is it a valid value
>> and if so should this be added somewhere in the docs? There is
>> currently no reference.
>> The second example is:
>> BACKGROUNDCOLOR -1 -1 -1
>> LABEL BACKGROUNDCOLOR was removed in 6.0 [3] but is still present in
>> mapserver\msautotest\misc\sde_utf2.map
>> One of the Python MapScript tests refers to this value as an "invalid
>> color" that should throw an error [4]
>> Any details on these 2 COLOR values appreciated,
>> Seth
>> [1]
>> https://github.com/mapserver/mapserver/blob/85e294e8c8ce3c9c455fea0137d4af1ee2feced0/msautotest/gdal/classtest1.map#L33
>> [2]
>> https://github.com/mapserver/mapserver/blob/06a076e9d0992f3ace676933ddcde87985feea31/mapserver.h#L369
>> [3]
>> https://mapserver.org/mapfile/label.html#mapfile-label-backgroundcolor
>> [4]
>> https://github.com/mapserver/mapserver/blob/85e294e8c8ce3c9c455fea0137d4af1ee2feced0/mapscript/python/tests/cases/color_test.py#L50
