[mapserver-dev] MapServer docs and index updates
Seth G
sethg at geographika.co.uk
Sun May 10 14:58:42 PDT 2020
Hi list,
I have added a pull request at https://github.com/mapserver/docs/pull/324 and would appreciate any feedback or objections to proceeding with adding a `:name:` to all the Mapfile index directives. I've included the text from the pull request below.
In summary all index directives would be updated from:
.. index::
pair: CLASS; BACKGROUNDCOLOR
to:
.. index::
:name: mapfile-class-background
Links in the index will then change from https://mapserver.org/mapfile/class.html#index-1 which can change to a fixed URL - https://mapserver.org/mapfile/class.html#mapfile-class-background
This would form part of the updates to the MapScript API documentation updates - see [here](https://github.com/mapserver/mapserver/pull/5870). Named index options allow an HTML link to be added from the MapScript docs to the relevant Mapfile keyword.
I've asked a [question on StackOverflow](https://stackoverflow.com/questions/61666809/parse-and-write-rst-using-docutils) to see if it is possible to automate it with docutils, but otherwise it will be a manual/parse/regex approach.
I added the `:name:` option to Sphinx as part of the version 3.0 release with [this pull request](https://github.com/sphinx-doc/sphinx/pull/7087), mainly for this use case. The docs for the option [are here](https://www.sphinx-doc.org/en/master/usage/restructuredtext/directives.html#directive-option-index-name).
I've created the pull request against master, but can make it against 7.6 if appropriate, and update the remaining Mapfile index directives.
Seth
web:http://geographika.co.uk
twitter: @geographika
