[mapserver-dev] MapServer docs and index updates
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon May 11 04:07:28 PDT 2020
No problem to include. Please make your doc PR to branch-7-6.
(you'll also notice my recent many commits to the docs, which now
require a minimum of Sphinx 3.0, and updated our documentation guide
accordingly for that requirement)
thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://gatewaygeo.com/
On 2020-05-10 6:58 p.m., Seth G wrote:
> Hi list,
> I have added a pull request at https://github.com/mapserver/docs/pull/324 and would appreciate any feedback or objections to proceeding with adding a `:name:` to all the Mapfile index directives. I've included the text from the pull request below.
> In summary all index directives would be updated from:
> .. index::
> pair: CLASS; BACKGROUNDCOLOR
> to:
> .. index::
> :name: mapfile-class-background
> Links in the index will then change from https://mapserver.org/mapfile/class.html#index-1 which can change to a fixed URL - https://mapserver.org/mapfile/class.html#mapfile-class-background
> This would form part of the updates to the MapScript API documentation updates - see [here](https://github.com/mapserver/mapserver/pull/5870). Named index options allow an HTML link to be added from the MapScript docs to the relevant Mapfile keyword.
> I've asked a [question on StackOverflow](https://stackoverflow.com/questions/61666809/parse-and-write-rst-using-docutils) to see if it is possible to automate it with docutils, but otherwise it will be a manual/parse/regex approach.
> I added the `:name:` option to Sphinx as part of the version 3.0 release with [this pull request](https://github.com/sphinx-doc/sphinx/pull/7087), mainly for this use case. The docs for the option [are here](https://www.sphinx-doc.org/en/master/usage/restructuredtext/directives.html#directive-option-index-name).
> I've created the pull request against master, but can make it against 7.6 if appropriate, and update the remaining Mapfile index directives.
