[mapserver-dev] mapserver.h and SWIG
Steve Lime
sdlime at gmail.com
Tue May 19 15:53:12 PDT 2020
Organic is a good word for it although there was some effort to group
related properties so numlabels, labels and maxlabels were are next to one
another. So this will scatter those a bit. Probably ok IMHO given the
advantage keeping some docs close to the base structures.
—Steve
On Tue, May 19, 2020 at 5:19 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I've opened a new pull request at
> https://github.com/mapserver/mapserver/pull/6071 which adds docstrings
> for the classObj properties available in MapScript. These can then be used
> to generate automated API docs for MapScript using Sphinx.
> When adding the docstrings it would seem to make sense to regroup the
> struct properties.
> I'm unsure if there is currently a logical grouping or ordering, or if
> properties have been organically added over the years.
> It would make sense while adding docstrings to reduce the number of SWIG
> guards, and regroup similar to below:
> struct classObj {
> #ifdef SWIG
> %immutable;
> #endif
> ..all SWIG immutable properties
> #ifdef SWIG
> %mutable;
> #endif
> .. all SWIG mutable properties
> #ifndef SWIG
> all non-SWIG properties
> #endif /* not SWIG */
> Does anyone see any issues with this, or reservations in general to adding
> the docstrings?
> I've read through
> https://stackoverflow.com/questions/26818011/does-the-order-of-members-in-a-struct-matter
> but there are no array properties (at least for classObj).
> Regards,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200519/7c392639/attachment.html>
