[mapserver-dev] mapserver.h and SWIG
Seth G
sethg at geographika.co.uk
Wed May 20 15:03:03 PDT 2020
Thanks for the feedback Steve.
How about the grouping in https://github.com/mapserver/mapserver/pull/6071/commits/bdf511a52b834715fc32c77e00173b842ca72b64 ?
%immutable;
%mutable;
non SWIG
I'll move the char *template; to the immutable section.
SWIG is used to document all struct properties plus their types, and Sphinx then makes them linkable.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Wed, May 20, 2020, at 12:53 AM, Steve Lime wrote:
> Organic is a good word for it although there was some effort to group related properties so numlabels, labels and maxlabels were are next to one another. So this will scatter those a bit. Probably ok IMHO given the advantage keeping some docs close to the base structures.
> —Steve
> On Tue, May 19, 2020 at 5:19 PM Seth G <sethg at geographika.co.uk> wrote:
>> Hi all,
>> I've opened a new pull request at https://github.com/mapserver/mapserver/pull/6071 which adds docstrings for the classObj properties available in MapScript. These can then be used to generate automated API docs for MapScript using Sphinx.
>> When adding the docstrings it would seem to make sense to regroup the struct properties.
>> I'm unsure if there is currently a logical grouping or ordering, or if properties have been organically added over the years.
>> It would make sense while adding docstrings to reduce the number of SWIG guards, and regroup similar to below:
>> struct classObj {
>> #ifdef SWIG
>> %immutable;
>> #endif
>> ..all SWIG immutable properties
>> #ifdef SWIG
>> %mutable;
>> #endif
>> .. all SWIG mutable properties
>> #ifndef SWIG
>> all non-SWIG properties
>> #endif /* not SWIG */
>> Does anyone see any issues with this, or reservations in general to adding the docstrings?
>> I've read through https://stackoverflow.com/questions/26818011/does-the-order-of-members-in-a-struct-matter but there are no array properties (at least for classObj).
>> Regards,
>> Seth
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200521/f1135f65/attachment.html>
