[mapserver-dev] Proposed budget expenditures...
Steve Lime
sdlime at gmail.com
Fri May 22 09:06:17 PDT 2020
I'd be happy to see you take on the 8.0 role, you did a great job with 7.6.
That said, are you proposing something different from a funding standpoint?
I do think milestones are the easiest way to carve things up, I mean you
have to have some way to know when something is done.
On Fri, May 22, 2020 at 10:57 AM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> My honest thoughts when thinking on the MapServer part is to put the
> amount into a 'release manager' role for 2020, and that would include
> the 8.0 release. (thinking along the lines of Daniel's great message
> from 2020-01-10 where the release manager helps with the initial release
> plus point/bugfix releases) So I guess my thinking is that the effort
> towards the 7.6.0 release helps us build towards the big 8.0 release.
> (the part in my head that I haven't said here yet out loud is that I
> also plan/hope to fill the 8.0 release manager role as well, as I see
> all of the team effort the past month or year spent as actually working
> towards the 8.0 release).
> My explanation is not as clear or concise as Daniel's ha.
> -jeff
> On 2020-05-22 11:48 a.m., Steve Lime wrote:
> > Hi all: A few milestones were reached this spring that were identified
> > as budget
> > (https://github.com/mapserver/mapserver/wiki/OSGeo-2020-Budget) items,
> > specifically $500 each for the release managers for MapCache 1.10 and
> > MapServer 7.6. While I'm sure that doesn't come close to covering the
> > amount of time Jerome and Jeff put in, it's still something.
> > I'd also like to propose allocating another $300 for Jeff's handling of
> > the PHP/MapScript security response - so from the emergency operations
> > line item.
> > That would leave us with $700 in our pre-allocated OSGeo 2020 budget for
> > the second half of the year.
> > Thoughts?
> > --Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200522/bb46a387/attachment.html>
