[mapserver-dev] MapServer docs and GitHub Process
Even Rouault even.rouault at spatialys.com
Sun Sep 20 02:18:48 PDT 2020
I'm OK with that. I've just done the exercise of merging the 7.6 branch to master. Technically
this is just a matter of running "git merge", but there are indeed the issues with conflicts.
There were a few here to solve.
One issue that we face regularly though to keep the stable and master branch in sync is the
issue of line endings. This is something we face independently of using "git merge" or
backport/cherry-picking of commits. Would be good if people could convince their text
editors not to alter the line endings. Or we might play with .git/config settings to decide for a
given line ending on the server.
Once we go for a backport-based workflow, git merge will no longer be usable, so this will
require discipline for people to make sure that whatever must be ported to the other branch
is done at the time the change is pushed.
Even
> Hi all,
> At the moment pull requests to https://github.com/mapserver/docs/ should be
> made to the latest active branch (currently 7.6). Documentation for new
> features however should be made to master (as they won't apply to new
> features). Sometimes it is difficult to know if a code change will be
> backported or not.
> There are several pull requests that have been added to the 7.6 branch that
> are not in master, and some in master that are not in 7.6. I'm not sure how
> these possible conflicts are merged following a release (likely a
> painstaking manual process by Jeff?).
> Would it make sense to follow the same development process as the MapServer
> codebase, and set up the GitHub "backport" bot? Then if code is backported
> the doc pull request can be too, and master will contain all updates.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200920/9cd21731/attachment.html>
